Ham Adif Logger_ software log da stazione radio amatoriale di nuova concezione .
The software I created, HAM ADIF LOGGER, is a completely new concept designed to run exclusively within a single page of your favorite web browser.
Unlike traditional software, this logger is "multi-instance." This means you can open the program on multiple monitors or different browser tabs simultaneously; since they access the same underlying database, all instances remain synchronized.
Key Features:
• OS-Style Interface: Floating, resizable, and cascading windows like a real operating system.
• Local File System: The program requires two local files: the contact database (.adif) and the partial control file (.scp).
• CW via USB Audio: CW transmission and reception via the PC/Radio sound card, without external interfaces.
• CAT Control: Integrated support via Web Serial API for ICOM, YAESU, and KENWOOD.
You can access the software using the following link: https://www.curiositaastronomiche.it/HAL/index.php
To access the program, enter the following credentials:
• CALL: USER
• PASSWORD: demo.
You can find the instructions in English at the following link: https://www.curiositaastronomiche.it/HAL/manual.pdf
yoytube video tutorial: https://www.youtube.com/watch?v=cvukKUqNnqE
Youtube video of real time audio routing and processor : https://youtu.be/FLv7g7TI530
youtube video of cw keyer simulator with Ham adif logger_ and real key in usb mode: https://youtu.be/oOdDiYfaog8
Il software che ho creato HAM ADIF LOGGER_ è un software di concezione completamente nuova progettato per funzionare esclusivamente all'interno di una singola pagina del tuo browser web preferito.
A differenza dei software tradizionali, questo logger è "multi-istanza". Significa che puoi aprire il programma su più monitor o diverse schede del browser contemporaneamente; poiché accedono allo stesso database sottostante, tutte le istanze rimangono sincronizzate.
Caratteristiche Chiave:
• Interfaccia OS-Style: Finestre mobili, ridimensionabili e sovrapponibili come un vero sistema operativo.
• File System Locale: Il programma richiede due file locali: il database dei contatti (.adif) e il file di controllo parziale (.scp).
• CW via USB Audio: Trasmissione e ricezione telegrafica tramite la scheda audio del PC/Radio, senza interfacce esterne.
• Controllo CAT: Supporto integrato via Web Serial API per ICOM ,YAESU e KENWOOD.
Potete accede al software utilizzando il seguente link: https://www.curiositaastronomiche.it/HAL/index.php
Per accedere al programma inserire le seguenti credenziali:
• CALL: USER
• PASSWORD: demo.
Al seguente link trovate le istruzioni in Italiano: https://www.curiositaastronomiche.it/HAL/manuale.pdf
73 de iu7iwt
